Here is how I got it to work, besides the proxy you need to install WIn DVD 7, get a demo from
www.intervideo.com, when you install it select to install the interactual player to...once the interactual player is installed, open it and got to the settings and update the software to the latest interactual player, you must update to the latest player so you have to make an account I think to regiter it, once done and updated open win dvd 7 go to options and and setup there is an option to play interactual features in interactual mode instead of dvd video mose, select that option...now you need ot verify it's all working, stick in the T2 disc, yes the 2nd one, play it in Win DVD 7, it should play in interactual mode, then follow the steps to play it, if you successfully get to the last part where it says you have the wrogn country code, then at least it's all working, now all you need is to find is a working proxy....from experience it must be a Transparrent US proxy, and must not use port 8080, 8000 or 80, as they are blocked, something like port 3126 should work...so just search the net for Transparrent US proxies...refer to the previous post on how to eneter the proxy...once done refrsh internet explorer and reload the dvd...
