wmv on udf cant run on my dvd
d2idan
i downloaded a mkv file --- converted him to WMV file
but nero says that the file larger then 2G so i will have to burn it by UDF
i did it but it dont work on my dvd.
how should i burn it ?
maybe i need to convert it to dvd with CONVERTxtoDVD ?
and id i do it the quality of the movie dont take damage ? (dont get low ? )
thanks
d2idan
what is the best quality of movie that i can get when i convert ?
i mean
from MKV to ???
wmv ? what is the best quality that similar to mkv ?
Hal_loe
when i use convertxtodvd i can burn the file.
but when i use video2dvd its say that my file (wen i want to convert) is too big. how can it be ?
http://img185.imageshack.us/img185/2325/lookkjh6.jpg
look...
please help...
what better quality ? VIDEO2DVD or CONVERTXTODVD ?
How long is the file you are trying to convert?
I don'y knoe VIDEO2DVD but you need to change to encoder settings to get it to fit. About 1 hour at maximum DVD-Video quality.
Hope that helps.
