WMP10 help required
Discussion in 'Microsoft Windows' started by sdavidsonuk, Sep 1, 2005.
  1. sdavidsonuk
    sdavidsonuk
    Jul 17, 2003
    1,687
    Killie - don't visit if you can help it
    +68
    I've installed WMP 10 last night and wished I'd never bothered as it just hangs as soon as I open it.
    I only downloaded it as the Microsoft site said WMP 9 was no longer compatible with Windows XP.
    Can anyone suggest how I can get this to work? Should I uninstall everything relating to Windows Media Player from my PC and start the install again? If so, which files should I be deleting from the add/remove program list? Media Connect?
    Any help much appreciated.
  2. DaveP
    DaveP
    WMP10 is part of the operating system now so you remove it from the "Add Remove Windows Components" part of "Add or Remove Programs"
  3. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
  4. sdavidsonuk
    sdavidsonuk
    Jul 17, 2003
    1,687
    +68
    thanks folks :)
  5. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Do you happen to be using Mcafee AV version 8.0 ?
