WMP and avi
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Aug 23, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    I've downloaded an avi of Top Gear and I've tried running it on WMP 10 but I don't get a picture. Sound is fine but no picture.
    Can't use anything else as it's a work laptop and I can't install anything.....booo!
    Any ideas ?
    Richie.
  2. Rambles
    Rambles
    Jul 14, 2004
    7,706
    UK
    +909
    Probably not got the right codec installed.
    Which involves installing GSpot to find out what codec it uses, then the correct codec (maybe divx / xvid)... if you can't install anything on the laptop you are a bit stuck... maybe you can transfer the file on to your own pc and play it on that?
  3. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    YO usually need to install the Divx codec, which you can get from www.divx.com...
  4. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    Or you could use Video Lan to view it. This little bootiful prog plays every format/codec i dare to throw at it :)
    Linkage
  5. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    I hate VLC, HD Videe skips with it and you get that annoying grey bar at the Bottom, I don't know why people praise it, Win DVD is far superior in terms of HD playback...
  6. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    +139
    I have never seen those symptoms, may i suggest that they are caused by another problem? I don't get a grey stripe anywhere and the HD stuff I have watched plays fine.
    WinDVD for me crashes as soon as I drag it to my second screen (projector).
  7. scumball
    scumball
    Jan 12, 2004
    6,394
    Harrow - London
    +439
    Install ffdshow for playback of all formats without the need for the proper codecs which are usually only really needed for encoding...
  8. Rambles
    Rambles
    Jul 14, 2004
    7,706
    UK
    +909
    The OP said that it is a works laptop and he is locked out of any installs...
  9. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    +139
    IIRC VLC can be run without installing. i.e. I install it (extract the cab files), zip it up and ftp it to the OP. OP then extracts the zip and runs with the command line parameters ... no registry access required :thumbsup:
    The key is the command line "C:\Program Files\VideoLAN\VLC\vlc.exe --intf wxwin --wxwin-embed" in my case.
    Get out of jail: Must admit though, i have dragged n dropped it to systems but ive never run it on a policy restricted system.
  10. scumball
    scumball
    Jan 12, 2004
    6,394
    Harrow - London
    +439
    Oh, sorry...
