wiring up speakers
Discussion in 'AV Receivers & Amplifiers' started by ewin, Mar 24, 2003.
  1. ewin
    ewin
    Feb 25, 2003
    123
    16
    scotland
    Can anyone tell me what wiring up in parrell and series means as i`m so stupid.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Series is amp>speaker>speaker>speaker>amp
    Parraleel is amp>speaker>amp>Speaker>amp>speaker>amp
    But why would you want to do this, what cables are using and what speakers????
    PS read the manual
  3. ewin
    ewin
    Feb 25, 2003
    123
    16
    scotland
    Because i`ve got ex 6.1 and want two rear speakers at the the back
  4. Sunday Ironfoot
    Sunday Ironfoot
    :rolleyes: :rolleyes: :rolleyes:
    Err...I wouldn't wire them up in series if I were you...you might blow something. In fact I don't think there's a speaker/amp combination in the world that can be wired as series, someone prove me wrong.
  5. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    I'm a bit rusty here, but don't you mean parallel?
    In series they increase resistance meaning lower current draw. I think.
    Ohms Law is V = I x R isn't it?
    V is voltage
    I is current
    R is resistance.
    So I = R/V
    Correct me if I'm wrong.:confused: :)
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Think you're right General.
    For example
    Parallel:
    1/8 + 1/8 = 2/8 = 4 ohms (not easy to drive)
    Series:
    8 + 8 = 16 ohms (easier to drive)
  7. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    Thanks for the back up. Nearly looked really thick there.:laugh:
    I remember an article in a Home Entertainment mag years ago, about someone called Hoffler (I think) who used speakers in series to do wraparound sound.
    I remember it, as it meant a low powered amp (low rear watts for mono pro logic surround amps in those days), could drive more speakers with less strain than driving just the pair. Odd how physics works.
  8. EvilMudge
    EvilMudge
    Tell me about it.
    BTW there are some golden ratios of input/output impedance which integrated amplifier and active speaker designers rely on, which do more for the sound quality of the product than a dual mono construction does (in reality) - which is why some integrated amps can beat pre/power combis at a similar price.
  9. chipper
    chipper
    Jan 21, 2003
    126
    +3
    I think I might have to correct you.
    If V = I X R
    then
    I = V / R
    :lesson: :lesson: :lesson: :clap: :clap: :clap:
  10. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Isn't it:-
    Power = Current x Resistance ( P = IR not V = IR )
  11. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    EvilMudge...the guy's name was Hafler,and the idea was to connect a rear speaker of suitable impedance across the positive terminals of the stereo amp and use the difference signal to drive a rear speaker for a sort of ambience feed....still didnt stop it melting the odd amp that couldn't deal with this sort of thing!
  12. andyk
    andyk
    Dec 31, 2001
    767
    46
    North Yorkshire
    +167
    No it isn't
    Ohms Law is V=IR
    the one you are thinking of is P=IV.
  13. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Oh, right you are then...has been 15 years since I last had to remember it!
  14. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    When speakers are connected in parallel, the impedance is reduced. This means that, given the same output voltage, the current demand on the amplifier will be increased. If all speakers have the same impedance, the total impedance is the impedance of a single speaker divided by the total number of speakers. If you have two 4 ohm speakers connected in parallel, the total impedance is 4/2 or 2 ohms. You must be careful when paralleling speakers onto an amplifier. The impedance can quickly fall below safe levels. This is especially true when connecting speakers in parallel onto a bridged amplifier.
  15. Jonathan West
    Jonathan West
    Best way to remember that one ...
    Power = Ivy Watts (gettit?)
    Physics teacher tought me that one along with the mechanics question starting "A balding mole is proceeding through the wood at 3 ms-1 ...."
