Wiring up speakers to amp
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Mundu, Mar 9, 2005.
  1. Mundu
    Mundu
    Jan 31, 2005
    162
    London
    +3
    Well my speakers have finally arrived and my speaker cable will be arriving tommrow so I thought this would be a good time to ask how to bi-wire my speakers to my amp.
    Amp: Cambridge Audio Azur 540A
    Speakers: Wharfedale Diamond 9.1s
    Cable: Chord Carnival Silver Bi-Wire
    So with some visual aids could someone please tell me what should go where.
    [​IMG]
    [​IMG]
    Thanks.
  2. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    695
    43
    +146
    Are you sure you've labelled your amp terminals correctly - they look wrong to me ?
  3. Mundu
    Mundu
    Jan 31, 2005
    162
    London
    +3
    The top ones are wrong will edit.
  4. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    695
    43
    +146
    A wiring diagram is attached.
    Two cables will come from each terminal on the amp.
    You must remove the two metal links on each speaker (one links the two red terminals - the other links the two black terminals). This will then make each of the four terminals independant on the back of the speaker.
  5. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    assuming you don't want to use the B outputs for another set of speakers, and the amp allows you to select both A & B outputs at the same time, it will be easier to use the A outputs for (say) the mid/treble drivers and the B outputs for the bass, since you don;t have the problem of squeezing two lots of cable into one terminal.
