Les Travers
Hi, I would appreciate some help with what is needed to connect a second tv in a bedroom. I currently have a tv installed in the lounge with a humax box and 2 cables going to a satalite dish.
I am converting a garage to a bedroom and I would like to fix a tv to a wall. I propose to install a second Humax HDR 1100 S on a shelf located on a shelf below the tv. I am fixing new plaster boards to the walls so concealing wires will not be a problem. My man concern is to avoid wires being visible. I can take 2 satalite cables and power cables to the position but I'm not sure what fittings I will heed to attach to the wall. Any help would be very much appreciated. Thanks, Les Travers.
