Wiring Speakers - 5:1 or 7:1??
Discussion in 'Home Cinema Speakers' started by Dazza7, Aug 28, 2005.
  1. Dazza7
    Dazza7
    I will be in the process soon of wiring up my room for speakers, as the cables are going to be plastered in I want to get it right. At the moment I have the standard 5:1 setup, is it worth wiring a 7:1 setup? My amp has the option for surrounds and rear surrounds so that's not a problem. Is there much use for a 7:1 setup? I can't remember seeing any of my DVD's showing anything more than a 5:1 option.
    Darren
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,549
    In a secret location with Jennifer Lawrence
    +7,360
    If it's not too much hassle it's always best to future proof yourself. SO I would go for the full 7.1
  3. clarky78
    clarky78
    Nov 8, 2004
    1,830
    Nottingham
    +37
    I was in this situation myself only 3 weeks ago. In the end went for 7.1 because I could. It costs more due to the extra cable and speakers, but i have several discs encoded in DTS ES. Blade II/III and LOTR ROTK for example. However i really dont notice hardly any difference, and maybe wouldn't have forked out for the extra speakers had i known. You can switch your amp into 6/7.1 manually for 5.1 films using DTS EX.
    I think it really comes down to your room layout if you will notice a big difference and if the cables are in the walls its kinda hit and miss for locations. but if your rooms larger and you sofa is quite far from the back wall (mine isn't) then it will probably be more beneficial anyway. And more and more films will come out in true 6.1 ES anyway.
