Wiring question
Discussion in 'Pro Audio and Musicians Forum' started by saranam, Feb 5, 2018.
  1. saranam
    saranam
    Nov 9, 2008
    9
    4
    Kendal
    Hi all
    I am hoping someone can help me out I have a vintage AKG Austrian made microphone but it has no connector I want to fit an XLR connector but im struggling to work out the wiring although I do have the original diagram of the wires. the mike has a rocker switch which locks in the forward position lays horizontal in the off position and has a on demand spring loaded in the back position any help would be appreciated. Opened up the mic and found the green and blue wires are not connected
    cheers
    Len
  2. dannnielll
    dannnielll
    Sep 16, 2017
    2,263
    113
    ireland
    +946
    If the technology is just a standard magnetic microphone ..which i suspect then connect the xlr between the red and white. You can check this out by just putting those connections into any amplifier and speaking into the microphone.
    If you want to mute the microphone arrange the switch to short out the red white connections.
    You need to check the xlr pin connections to suit your amplifier..
