wiring problems
Discussion in 'Video Streaming Boxes & Services' started by shady786, Mar 26, 2006.
  1. shady786
    shady786
    hi every one,
    i need some help with wiring my fusion jonah lomu fjl 1211d amp, it has 4 gauge power cable terminals and ive been told that it needs 0 gauge power cable coz the amp is 1250 watts rms, my m8 told me that i shuld get a 0 gauge wire then convert it to a 4 gauge near the amp using a fused distribution block?
    is there any point doing that or is it the same as using just a 4 gauge wire from the battery?
    a answer will save alot of headaches and prob money :suicide:
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
