Pugs1
We are buying a new bungalow and I want to ask the builder to incorporate cat6 cable to some of the rooms as well as add speaker points in the living room for 7.1. It is also a chance to tidy up the mess behind the AV\HiFi systems...hopefully
I'm thinking that the main components I need for a home network would be
1. Network Switch
2. Switch Panel
3. Router\ADSL Modem
4. Cat6(?) Cable\Wiring
5. Termination\wall sockets
Rooms to be networked
1. Living room (AV, HiFi, Xbox, Sky HD, Blu-ray, TV – the last four have internet access)
2. Study (home working)
3. Bedroom 1 (TV, possibly Sky)
4. Sunroom\kitchen (TV)
The main network components can be hosted in a hall cupboard where the main fuse box is situated but I think I'll need two twin electrical sockets added. However, since the router\modem will be in here, should I have main BT point terminated here?
My idea is just to have one cat6 cable running to the rooms above, is that enough, should I have 4 network points (RJ45) in the living room? Should I run twin runs to the other rooms, esp Study?
What would be the correct way to terminate this lot?
Main Components for AV – All using HDMI
1. AV Amp – not networked
2. Plasma TV – RJ45 connection
3. Blu-ray – RJ45
4. Xbox360 – RJ45
5. Sky HD – RJ45
6. HiFi – TAG McLaren
7. 7.1 speakers (main front left\right are shared between the HifI and AV)
Obviously in this case, most of the equipment will be on one main wall. So requirements will be
1. Extra electrical sockets perhaps 4 x twin sockets
2. RJ45 sockets
3. Speaker sockets for rears\surrounds and possibly the sub (Single RCA termination)
4. Connections between HiFi and AV – would need long set of RCA cables
5. Anything else?
Even though new cat6 points and speaker sockets would be installed, how else can I cable manage the rest of the connections i.e. HDMI out from components to AV amp and\or TV and optical connections etc?
Now to the nitty gritty, can anybody recommend the correct cabling for this lot. I know that there are certain Cat6 cable suitable for in wall installation
I would need a few details on suppliers or where to purchase
1. Rolls CAT6 (7?) In wall cabling
2. Longer RCA Cabling
3. Suitable network switch and panel
4. Suitable sockets\plates
5. Rolls of suitable 'in wall' speaker cable
Is it worth asking the builder to add a dedicated electrical line to the main fuse box for this lot?
Thanks for helping out
1. Network Switch
2. Switch Panel
3. Blu-ray – RJ45
4. Xbox360 – RJ45
5. Sky HD – RJ45
2. RJ45 sockets
5. Anything else?
