Wiring Multi-strand cables to screw terminals
Discussion in 'Cables & Switches' started by diddyg, May 23, 2005.
  1. diddyg
    diddyg
    Very basic question coming up so prepare yourselves!
    I am now the proud owner of some un-terminated multistrand speaker cable which I am going to hook up to my speakers that have standard screw terminals. I am going to have to strip back the cable and twist the end of the wires to wrap around the speaker terminals but I am wondering whether this is really the best idea or not! The strands are not that thick so is there something clever I should be doing or am I being paranoid?
    D
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Well the ideal solution would be to "tin" the ends of the wires (after twisting them together) with a soldering iron & solder. If you haven't got a soldering iron, then just twist the wires as tightly together as you can without straining them.
  3. diddyg
    diddyg
    Thanks Nick.
    I don't have a soldering iron so I will try the twisting solution and if it doesn't sound to good I will strip it back again and solder.
    Cheers,
    D
    :thumbsup:
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
