Wiring Monitor Audio BX2's
SPB
I am only going to single wire these but do I connect the wire to HF or LF, does it make any difference, most people say they connect them to HF?
There are some who say it DOES make a difference which terminals the wire from the amp connects to FIRST.
There are some who maintain that it is better to use CABLE to connect the corresponding HF and LF terminals together.
The speaker manufacturers usually supply suitable solid links for this purpose.
Personally, I connect the cable to the LF terminals and use the supplied solid links.
Any perceived differences in sound from different connection schemas must be minute, as it's only an inch or 2 of cable we're talking about !!!
It's really up to you !
PSM1
As above, connect to either. I believe convention normally states you connect to the LF terminals but do not think it makes any difference really.
