Wiring JS RGB to Component box
Discussion in 'Plasma TVs Forum' started by groove, Mar 17, 2005.
  1. groove
    groove
    May 26, 2003
    495
    46
    +160
    Hi guys, call me stupid but im going to start wiring all my new kit up tonight and im unsure of what lead goes where on the JS RGB to component box.
    The instructions say it has 3 video connections labelled Y U and V
    I have a cmponent cable that is Red Green and Blue
    Which ones connect to which ???
    Sorry for the noobness
  2. Slartibart
    Slartibart
    I couldnt work it out at first rang the factory no one there to help,running mine after some research Green Blue Red with scart on right....seems to work picture fine
    so much for RGB
    Regards
    slarti
  3. groove
    groove
    May 26, 2003
    495
    46
    +160
    How can one type of connector have 3 differnet ways of labelling it ? Blows my mind.
    I was going to go G R B as that is the order on the back of my dvd player , but still not sure...
    Do you know what would happen if they were wrong ? Would you get nothing ? Or a picture but lower quality than it should be ???
    Or will it all self destruct :eek:
  4. c4lln
    c4lln
    red=y
    green=u
    blue=v
    according to js website
  5. Slartibart
    Slartibart
    i went with the logical r red g green b blue first nothing
    i tried other comb got nothing .. I was inputting to a hs50 proj not a plasma so beware...others on this board are far more Knowledgeable
    The box to be fair is great left on all the time and does not overheat
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    c4lln is correct...
  7. c4lln
    c4lln
    do you have to change the settings on the projector to accept component?
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Some DVD players helpfully label the sockets! I guess coloured sockets would have added to the price, and how much has it cost you to find out without that?
  9. Slartibart
    Slartibart
    No it has sep component inputs also run in Hdmi from a pio 868avi , you select the input from the remote
  10. groove
    groove
    May 26, 2003
    495
    46
    +160
    Nice one guys , thanks for all your input....hopefully have this up and runnning tonight then ;-)
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,930
    The Borders
    +3,573
    groove
    Before you do anything you need to ensure your Digibox has been set to RGB - best to do this whilst its still connected to your old TV or grab a portable as you cant see the on screen menus via the RGB converter if the Digibox is set to Output Composite (SKY call it PAL).
    Joe
  12. groove
    groove
    May 26, 2003
    495
    46
    +160
    mmmm , something not right here, no picture
    Just to clarif checked the back of my PWD7 and this is how the component BNC leads are connected -
    Pr/Cr/R - Red
    Pb/Cb/B -Bue
    Y/G - Green
    Tried on the JS with -
    Y - Red
    U - Green
    V - Blue
    Also checked Sky on the other TV, it is set to RGB and SCART CONTROL is on?
    Any ideas guys , the living room looks like a bomb has hit it !
  13. groove
    groove
    May 26, 2003
    495
    46
    +160
    PS connect JS to sky+ with brand new 0.5m QED SQUART lead, also tried another spare fully wired scart and still no picture with that one.
  14. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    assume you selected component signal on screen?
  15. groove
    groove
    May 26, 2003
    495
    46
    +160
    flicked through the inputs and only have PC, DVD3 and Input2 coming up.
    The dvd input was from where i had my dvd player connected to it breifly last night to test the screen and that was connected with the same component lead i am trying to connect the JS box with so i know that lead is good.
  16. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Didn't spot the deliberate error there. Y=G U=B V=R The Y on it's own should give a B/W picture.
  17. Slartibart
    Slartibart
    why does mine work on green , blue , red.
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    do you have a dual slot board? 5 BNC? if so you need to select it as component input select the input and press "SET UP" then select Component and make sure the cables are connected properly and the BNC's are twisted all the way round.
  19. groove
    groove
    May 26, 2003
    495
    46
    +160
    Nice one MAW !!!!!
    I have a picture.....helps if the cables are the right way round i suppose ;-)
    Back to work then, thanks again guys....dont know what id do without you :clap:
  20. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,930
    The Borders
    +3,573
    I have to admit I was being cruel - spotted it first time around but had to go get dinner and didn't have time to make another post.
    Joe
  21. groove
    groove
    May 26, 2003
    495
    46
    +160
    no worries, Just put my Yamaha 750 into the equation...and I still have a picture !!
    No sound yet, but im getting there...slowly.......
