Wiring in series
Discussion in 'Home Cinema Speakers' started by PaulaB, Dec 27, 2002.
  1. PaulaB
    PaulaB
    Mar 6, 2002
    242
    Northamptonshire
    According to the info I got from mission;
    Most EX based AV amplifiers support connection of a pair of rear channel speakers. if only a single connection is provided for the rear channel, the 'ds' speakers should be wired in series.
    Does this mean put both + and both - in the + and - connecters?
  2. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
    You will be wiring them in parallel not series this halves the impedence, and yes both +Vs together and both -Vs together, if you dont do this your speakers will be out of phase.
    To wire in series you would need to take the +Ve wire from one lead and join it to the -Ve wire of the other lead. You will be left with one -Ve wire and 1 +Ve wire to fit in the amp.
  3. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Hi paul you mignt find this of some use,
    This
