Wiring help please
Discussion in 'Home Cinema Speakers' started by JSW, Feb 25, 2002.
  1. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Have just bought the following speakers:
    Mordaunt Short
    MS 906 for front
    MS 905 Centre
    MSW 20 Sub
    Eltax
    Linear Response B.6 rears
    Have the Sony STRDB 1070 arriving Thursday
    Wats the best way to wire the 906's theyre biwireable?
    Wats the best way to connect my Sony 735 DVD to the amp, coaxial or optical?
    Wats cheapest good qlty cable I should use for all speakers?
    TIA
    JSW
  2. bob007
    bob007
    If they have bi-wire connections i would be inclined to bi-wire them.
    I use Coaxial, but there is not a lot between them in a short distance, if anything.
    QED and IXOS seem very popular, prices from about 99p/metre
  3. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Thanks bob.
    I have never had biwireable speakers before so is there a url handy for more info diagrams etc?
    JSW
    Edit:
    Found a nice simple diag Here
  4. bob007
    bob007
    If you do bi-wire don't forget to take the jumper plates off at the speakers terminals.
  5. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    K m8 Tks
