snaphappybob
I have a surround amp (Dspax759se) wired to a dvd/sacd(Marantz dv6001) player using the 6 channel output/input. When sending the signal from the dvd player to the amplifier digitally using common or garden Dvds all is well, however when using the 6 channel input the rear right speaker outputs no sound. I suspected a fault and have undergone wholesale change of the dvd player the amp to those abov, plus interconnets so everything within the chain has changed save for the speaker cable. As the speaker does work under non 6channel input usage this would discount the possibility of the fault lying in that department. I'm quite technically minded but at a loss as to the cause of the problems!
Anyone got any ideas?
