Wiring for Wharfdale Loudpanels
Discussion in 'Home Cinema Speakers' started by montyc, Nov 26, 2003.
  1. montyc
    montyc
    These have arrived with no instructions. Where does everything go??
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    Wire the amp into the sub like normal speakers IE +ve left on amp to +ve left on sub etc.. then wire the set of outputs on the sub to the panels IE +ve right output to +ve on right panel.
  3. gusf1
    gusf1
    Sep 25, 2003
    113
    Edinburgh
    +6
    I remember there being a few more instructions than that Re: best placement etc. I'll see if I can find them for you.
  4. gusf1
    gusf1
    Sep 25, 2003
    113
    Edinburgh
    +6
    ok I found them if you PM your email address I'll scan and send them on if you like
  5. montyc
    montyc
    I have one long red & black cable, which speaking to Richer Sounds needs to split and ran from the amp to the sub. Then there is some flat cable in two short runs which I take it run from the sub.
    Is this correct?
    The cables are all a bit on the short side. Can I use my silver anniversary cable instead?
  6. gusf1
    gusf1
    Sep 25, 2003
    113
    Edinburgh
    +6
    Email sent with instructions, hope PDF format is ok
    Anything is probably better than the cables supplied, I don't use silver anniversary but at least used some medium quality from RS instead
    Instructions sent should clear up any issues with how to connect if not just post back here.
