Wiring for Fibaro Single Switch 2 not working
freddyq
Hi, can anyone with experience of wiring Fibaro modules advise why the wiring in the photos isn't working?
This is a Single Switch 2 module wired to a standard toggle on/off switch controlling 4 LED outdoor lights...
TIA!
Desmo
I'm not a pro on this, but shouldn't neutral also go in to Q?
Desmo
Hang on, you've not got a neutral wire have you. Your load from the light should be in Q but you then need a neutral for N.
freddyq
I'm no electrician and this is being done by someone else but this is for a new extension where new wiring has been run for new lights and switches so how do you normally end up with neutral at the switch? Can I get it run now?
Desmo
I doubt it can be run now as your wiring is behind the plasterboard but ask your sparks/builder. I'd imagine it's an older house without a neutral (most newer houses have it at the switch) so I'm guessing they've carried on with this in the new extension.
If there is a neutral at the light itself you can wire the Fibaro unit there instead.
freddyq
OK thanks - issue is the lights are outdoor lights so highly unlikely I'll be able to wire directly at the light...
Desmo
Have a chat with the sparks, there might be a place close enough you can access all the wiring including a neutral :)
