silentandy
I have installed one of these Modified ADSL Adaptor for BT NTE5 at the main socket into the house and taken a CAT5 cable from it into a patch panel in the loft.
For the phone extensions I have these going into a port in the patch panel which are then wired in series to 3 other ports so I can patch up to 4 telephone extensions anywhere there is a RJ45 socket in the house. That works fine with a RJ45 to BT socket adapter for phones.
What I'm unsure of is how to connect the unfiltered terminals labelled A & B for the ADSL connection. I want to be able to have this as a port on the patch panel so I can also patch it into the router wherever in the house. I've used a spare pair on the CAT5 from the NTES socket to the patch panel but unsure which pins these should be connected to, I think 4&5? If so am I right in thinking I can then just plug the RJ11 ADSL cable into the RJ45 port and into the router?
