Wiring a Shelly Dimmer2 into my existing 3-way kitchen circuit
rkhanso
Hello,
I've searched the forum and online. I didn't find an example like my kitchen lighting (or didn't understand it the same, anyway).
Wondering how I'd wire a Shelly Dimmer2 into this circuit, keeping the two physical light switches able to turn off the light, as well as using Home Assistant.
Pictures are attached.
The first picture is my existing wiring. The second is my "guess" how to connect the Shelly Dimmer2.
Thoughts? Before I burn the house down?
These are the newer "Neutral wire not required" type of dimmers. Might that come into play for me?
Thanks.
Seb Briggs
My advice is pay £50-100 for an electrician to do it right for you , you are using a £20 module so just bite the bullet and make it work
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
