Wiring a passive sub
Discussion in 'Subwoofers' started by Epoman, Jul 25, 2002.
  1. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    Stupid question but how do you connect a passive sub (the one that comes with the Sony DAV-S300 system) to a DD 5.1 amp (Denon 3802)?
    I think I know the answer - something to do with connecting the +ve from the sub to one speaker terminal and the -ve to the other? i.e. Similar to the Rel high level connection.
    I don't want to experiment in case I blow it up :eek: (like I did the power amp I bought from this forum the day I got it home:blush: ).
    Ta
    Im
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Most passive subs are connected directly to the speaker terminals and presumably you would set the front channels to LARGE in the system setup menu.
    A powered sub would be better though and also places less load on the amplifier (bass is difficult to drive, hence powered subs!)
  3. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    Thanks Jase
    I've already got 2 Rels. The passive Sony is for a second system.
    Can anybody tell me whether I'm right about the +ve/-ve bit?
    Imran
  4. JimNoble
    JimNoble
    Aug 2, 2002
    63
    Hemel Hempstead
    +7
    If you have only a single passive sub, it needs to be fed an amplified signal that contains both left and right stereo signals.
    The simplest (only?) way you can do this, is to use a subwoofer output from your multi-channel decoder/amp. If you only have a line-level output, you will obviously need to amplify it!
    Jim
  5. Tejpal
    Tejpal
    stupid question,
    but is it possible to put both of you amplifier speaker out puts into one speakers, making twice the power??
    i dont want to try.... im not sure if my amp will short curcuit
  6. JimNoble
    JimNoble
    Aug 2, 2002
    63
    Hemel Hempstead
    +7
    Only if your amplifier is "bridgeable"
    Jim
  7. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    ....but the sub only has speaker connections:confused:
    Im
