Wiring a outside security light sensor
Discussion in 'Home Cinema Buying & Building' started by Hill1, Oct 25, 2005.
  1. Hill1
    Hill1
    Jul 30, 2005
    112
    east kent
    I have had to replace the PIR sensor (PIR motion detector) for my outside 500w light.
    On the sensor there is a white,brown and blue cable
    from the house there is a blue,brown, black and green/yellow cable.
    How do I connect these cables.
  2. miggsy
    miggsy
    is it a all in one jobby ie light and pir together
    or seperate
  3. Hill1
    Hill1
    Jul 30, 2005
    112
    east kent
    It's seperate
  4. miggsy
    miggsy
    ok try this blue to blue
    brown to brown
    white to black as this must be the switch wire to turn light on the others are the live and neutral
    green and yellow well put in a connector block as the sensor shouldnt need a earth as its probaly double insulated
    hope that helps
  5. Hill1
    Hill1
    Jul 30, 2005
    112
    east kent
    Thanks Miggsy, it worked a treat.
  6. miggsy
    miggsy
    no worries m8
