Wireless USB A to B
Discussion in 'Computer Peripherals & Consumables' started by madman1887, Aug 20, 2013.
  1. madman1887
    madman1887
    Dec 3, 2011
    213
    UK
    +7
    I'd like to know if there are any solutions which can provide me with an effective replacement of an USB A to B cable.
    I'm looking to connect my MacBook Pro to my Pioneer DAC wirelessly, but with as low latency as possible and able to send over lossless audio.
    The Arcam rWave/rDAC is the sort of thing I'm looking to achieve.
    Any ideas?
  2. dbeevers
    dbeevers
    Feb 21, 2008
    910
    43
    Sheffield
    +133
    Would not Pioneer's AS-WL300 work or an Apple Airport Express?
  3. madman1887
    madman1887
    Dec 3, 2011
    213
    UK
    +7
    It would to an extent, but I want a of my Mac's audio to be sent over to the external dac, and the Airport Express has a good 2 second latency which is very annoying. If the latency can e sorted then great, otherwise it's the USB interface for me.
  4. dbeevers
    dbeevers
    Feb 21, 2008
    910
    43
    Sheffield
    +133
    Not knowing the DAC I've just looked at it and it says has Airplay audio streaming, Airfoil would enable you to send all sound from your Mac to it (I think?) you can download a demo from here Rogue Amoeba | Airfoil
  5. next010
    next010
    May 29, 2005
    10,765
    163
    +2,107
    According to the devices specs your N50 is an Airplay device already and a DLNA renderer too.
    Have you tried using it with airplay directly ?
    If there is still a delay thats bothering you, try connecting the Mac and N50 over ethernet, remove wireless from the equation.
  6. madman1887
    madman1887
    Dec 3, 2011
    213
    UK
    +7
    Airplay has a two second delay on the sound which is terribly annoying. Bluetooth streaming is so much more acceptable in terms of latency.. Only if if it was lossless.
    Anyway I give up on this question and I guess I'll just have to work around it. Thanks for the contribution though!
