Wireless Transmitter and Receiver
Discussion in 'AV Receivers & Amplifiers' started by M8te, Jun 16, 2004.
  1. M8te
    M8te
    I'm trying to find reviews or ask around on a forum for info relating to any wireless transmitter/receivers of audio or of audio/video.
    I want to transmit audio from a PC upstairs to be received at the Hi-Fi downstairs, could anyone give me any pointers?
    The budget ideally would be around £50 but I appreciate this may have to be increased
    Cheers for any help
  2. cwoj
    cwoj
    you can only get video/images as stills!! I think?
  3. ccparkhill
    ccparkhill
    Oct 18, 2003
    507
    London, SE1
    +14
    Take a look here.
    Don't know much about how good it is, but fits you budget, here.
  4. jeff-o
    jeff-o
    There are lots of options out there. A good one (I think) is made by Roku, www.rokulabs.com . Do a search on www.google.com for "wireless media" or "wireless audio" or "wireless video" or something like that. I have a list of such devices at home, but I'm at work right now...
  5. nikyzf
    nikyzf
  6. jeff-o
    jeff-o
    Ah yes, with AirTunes. Unfortunately, I don't think this particular product is really what M8te is looking for...
  7. nikyzf
    nikyzf
    (Sorry, I should have said AirTunes, not iTunes.) I thought it was what he wanted, apart from the price :eek:)
    <I want to transmit audio from a PC upstairs to be received at the Hi-Fi downstairs, could anyone give me any pointers?
    The budget ideally would be around £50 but I appreciate this may have to be increased>
    Of course, he will need a wifi card or adaptor in the PC. The Airport will then do the rest.
  8. MN8
    MN8
    Thanks for the pointers but could you please explain WIFI card and what it does.
  9. nikyzf
    nikyzf
    WiFi is another term for wireless networking. There are 2 standards, 802.11b and 802.11g, the latter being 5 times as fast. Normally, you'd have a wireless base station connected to your modem, or one with a built-in modem, and then have wireless cards in your PC, or use a wireless adaptor or bridge. This way you don't need any cables between your PC(s) and the modem and you have a "wireless network". D-Link, Linksys, and Netgear are 3 common makes of wireless gear. Apple's name for this is Airport (802.11b) or Airport Extreme (802.11g). The Airport Express is also 802.11g but has a built in audio section to plug into your hifi.
    If you go this route rather that an audio-only wireless system, you will also have a wireless network for your PC data traffic (email, web browsing, etc.)
    I'm considering this myself :eek:)
    HTH, LMK if you need more detail.
