Wireless speed drops
Andy3105
:hiya:
I have a problem with my wireless performance, basically I struggle to get above 54mbps, the card in my PC is Wireless N as is the BT Home Hub 2.
If I change channels I can get a reported 130mbps in the Hub firmware but upon refreshing the screen it always drops to 54mbps or lower, I have also tried a Netgear WN111v2 adaptor and that suffers the same issues.
I have read some things on the net alleging that using WEP security can cripple wireless speeds and recommendations to change to WPA2 but I cannot understand why this would be an issue?
Hopefully someone far more knowledgeable than me can help me with this as it's seriously driving me mad :mad:
beerhunter
Start by reading one of the many threads on these forums about using inSSIDer to fix WiFi problems. (The question gets asked almost daily - twice today.)
If you have a HH 2.0 then it will be set to WPA2 by default.
Andy3105
I already have inSSIDer and have used it many times, when I change the channel the speed jumps to 130mbps but always drops again right away.
I changed the security to WEP myself so I might change it back just to see but I was hoping someone might recognise a solution.
beerhunter
And when you do that, do set the BT HH to a channel that is not in use and at least two away from any that are?
Andy3105
yes, I have tried several different channels always at least 2-3 channels away from the other wireless network it picks up which is out next door neighbour.
It always displays the same behaviour, I tried the WN111 just to see if it was an issue with the wireless card in the PC but that behaves exactly the same.
Andy3105
:hiya:
Thought I'd give an update and then this thread can be closed off I reckon....
I switched to WPA2 security and I did see an increase in speed 104mbps and also an increase in signal strength but this morning when I switched on the pc it had dropped to 38mbps and no other devices were connected.
I installed an extra powerline adapter that I got from BT and connected by ethernet and the internet performance is way better, really fast and responsive so I have decided to stop using wireless as it's simply too much hassle.
I have a powerline in the conservatory which serves my TV, Xbox360, PS3 and HD-DVD player and I have never experienced a disconnection so I think this is the way to go for me, I can't directly connect to the router because of it's location so a powerline adapter is the only solution but it seems to work just fine :smashin:
Trending threads
