Wireless speakers for 32PW9527
Discussion in 'TVs' started by davidgirecourt, Apr 23, 2003.
  1. davidgirecourt
    davidgirecourt
    Hi all
    Does anyone knows where I can find the wireless set, are they any good, sureley there must be a wire?
    David
  2. lespaton
    lespaton
    I imagine you could order them from a Phillips TV dealer.
    They are "wireless" only in respect of the connection from the TV to the speakers. One of the speakers plugs into the mains supply, the other is connected to the first by a length of speaker cable. The active speaker (the one plugged into the mains) can be designated either L or R by a switch.
  3. davidgirecourt
    davidgirecourt
    i'll buy a pair and see how it goes.
  4. Jamiethorpe
    Jamiethorpe
    I had a pair of these that were supplied with my PP+9617 (which has since been swapped for an FQ80 due to the infamous black bars)..
    The speakers were OK, I thought the (nearly) wireless solution made for a neater living room.
    My only gripe was that they would momentarily cut out when someone entered the room and happened to walk in between the TV and the speakers:(
  5. davidgirecourt
    davidgirecourt
    Hi Jamie
    I'll have the speakers delivered tomorrow. I did read a lot about the black bars but never had any prob with my screen so far!!!
  6. Jamiethorpe
    Jamiethorpe
    If you've not got the black bars then you've been very lucky?!
    My 32PW9617 was a cracking TV and I was loathe to give up on it for a Sony, but I just couldn't get a set without the black bars problem.
  7. davidgirecourt
    davidgirecourt
    Got my speakers an hour ago but I am at work, look forward to install them. I did think before buying my screen but never realized that the problem was so important.
