Wireless speakers and DVD recorders
Discussion in 'Home Cinema Buying & Building' started by Calvados, Jan 3, 2005.
  1. Calvados
    Calvados
    Jan 2, 2005
    116
    +3
    Can anyone recommend a system (under £550) that comes with wireless speakers? Or is it a 'no-no'- does quality suffer?
    Also, are there any reasonably priced systems that include a DVD recorder or am I best getting a good system (Denon seems to the one of choice here) and then buying a separate DVD recorder? Again opinions and recommendations welcome.
    Thanks in advance :lease:
  2. lesliedocherty
    lesliedocherty
    currys have one at the moment,
    its a philips one with wireless rear speakers, reduced down to £249, cant comment on quality but i need wireless rear speakers and this would be a start.
    leslie
  3. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    The thing to remember though is usually the back speakers will be wired together and need to be plugged in - less wires.
  4. Si133
    Si133
    I bought the Philips wireless system at the weekend. Took it back today. The wireless part was faultless. the sound was great. But the the picture was weak and dull. Once you try composite, you can't go back!
