Wireless Speaker Packages
Discussion in 'Home Cinema Speakers' started by moocifer, Aug 4, 2006.
  1. moocifer
    moocifer
    Jul 27, 2006
    67
    11
    Nottingham
    +3
    Can anyone recommend a good Home Cinema Wireless Speaker package ?? :lease:
    I already have an Amp & DVD player so preferably I am looking for just the speakers themselves and the accompanying control unit.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,756
    The Borders
    +3,520
    Hello moocifer
    Seems to be a popular 'topic' today - keep in mind with 'wireless' loudspeakers you may not require individual loudspeaker cables to each location but you DO require a mains socket at each location; hardly ideal if you follow the correct guidelines for loudspeaker set-up in a 5.1 room.
    I think too the term' good' takes on a relative meaning with the Wireless technology that's currently available - its always going to be a big compromise compared with a piece of copper speaker cable from your AV Receivers loudspeaker outlets.
    Have you considered the Yamaha Digital Sound Projectors - it'll mean ditching your AV Receiver but may achieve what you want in terms of a wire free installation; see http://www.yamaha-uk.com/sound_projectors/
    Best regards
    Joe
  3. jdT05
    jdT05
    If you do decide to go down this route then you'll definately want a sub as well.
    The yam does sound a bit tinny without one.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,756
    The Borders
    +3,520
    Hello jdT05
    Agreed the DSP is a 5.0 system so in all but small rooms ought to be partnered with an Active sub.
    Mind you on its own it'll sound ten times better than any 5.1 wireless system!!!
    Joe
