wireless sound quality
Discussion in 'Headphones, Earphones & Portable Music' started by Optiplex, May 24, 2005.
  1. Optiplex
    Optiplex
    Nov 29, 2004
    56
    Just bought the Philips SBC HC8850. I realise that these are the cheaper end of the market and you usually get what you pay for. However, is it the norm for cordless headphones to have quite a bit of interference. I understand that they are transmitting a FM signal but what's the point of making cordless headphones you get a hissing background noise from them. I've tried retuning numerous times but doesn't make any difference. Can anyone recommend a pair that under £100 that doesn't have too much interference. I want them for listening to DVDs and music. The Philips have a pseudo surround sound so would be looking for something comparable.
  2. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    I had a pair of AVG wireless headphones and they were rubbish.If you turned your head the wrong way you lost the signal and ended up with interference.They cost £60 and they ended up on ebay.My advice stick to wired fones.
