Wireless Signal Strength???
oldman100
Is there a means of determining what signal strength your Wii is receiving?
norealplan
Go to the Wii menu, go to network connection or something like that, and it should show the wireless network you are on. Next to it are some bars, obviously the more bars, the better the signal!
sjw
Really? (written on a Wii - wish you could copy/paste on it) Can't see it......... :(
Can see some 'tabs' but thought that was just the number of screens in you were.....
oldman100
Got to admit I can't see / find it either.
Andrew_arkless
You get a signal strength bar when you set up a new connection, search for new wireless networks on the setup screen & it will show you all available access points & a signal strength for each.
sjw
So if you need to enter it manually (as you should - because you shouldn't be broadcasting your SSID..), how do you see the signal strength?
Daz CPFC
If you have MAC filtering i dont think it would really matter if you broadcast your SSID as anyone with out the speicifed MAC address can access it.
sjw
Believe me it would... it's a lot harder to get onto a system that you can't easily even see compared to one you know is there but only allows certain MAC addresses to access it.
Most owners probably leave it set to a default 192.168.1.100 - 192.168.1.199 range too.
And with default passwords.. :( Not too difficult at all actually. Esp. with only WEP encryption. Make sure you use at least WPA. Shame you can't for the DS though..:thumbsdow Shame that can't be added by a firmware update.?..
