Wireless Setup With This Router
Discussion in 'Xbox Forums' started by ocnippz, Mar 8, 2006.
  1. ocnippz
    ocnippz
    I have the WIRELESS-G BROADBAND ROUTER WITH SRX
    AKA WRT54GX VER. 2 HOW CAN I GET IT TO WORK
    IT WILL NOT READ AN IP ADDRESS, it connects to the internet perfectly fine just the xbox 360 gets nothing. What can i do to fix the problem?
  2. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,584
    2
    137
    Glasgow
    +606
    Run the Live tests, read your router manual..then you can also read the Xbox forum on setting live up via a router.
  3. Grim Reaper
    Grim Reaper
    Aug 14, 2005
    74
    Cambridge area
    +4
    A little less shouting and a more detailed description would go a long way.
    http://www.catb.org/~esr/faqs/smart-questions.html
    Try assigning a static IP address to the XBOX 360. There are various posts around here that will help you do that, and google is your friend.
    Jim
