Wireless settings help
marshall010
How can i get my wireless settings back on to my laptop,the said laptop has been reset to factory settings and can still pick up my wireless but i cant get on the settings page the 192.etc etc,do i have to run the install disc again and if so will this change my settings?
Thanks for any info and help:thumbsup:
madhouse
normally you should just need to search for wireless networks, click on yours when it is found and enter your password when prompted. No need to access the router.
Hope this helps,
Simon
EndlessWaves
All you need to do is put in the address, often http://192.168.0.1 or http://192.168.1.1
Obviously you'll have to be connected to the wireless network first, if you need to get into the settings to get the password for the wireless then you'll have to connect using a cable (or look it up on another computer connected to it)
Neorion
if its a BT router (wireless box) then the password should be on the back.
