Wireless sender for Sky
Discussion in 'Sky Digital TV Forum' started by jmjm, Jun 21, 2004.
  1. jmjm
    jmjm
    Can anyone recomend a wireless Rf sender or whatever they are called that I can plug one end to the end of the sky connection and the other into my portable LCD so that I can watch it upstairs without cabling. I've seen a load in the ARGOS catalogue but I can't work out which ones are wireless.
  2. jmjm
    jmjm
    I appreciate that this trivial question is beneath your vast intellects but I'd appreciate some advice - even if it is to tell me this is not possible.
  3. sparkybun
    sparkybun
    Jan 6, 2002
    1,237
    41
    EN8 area
    +23
    One For All SV1720 is a pretty good one from Currys or most shops.
    cheers
    Mel
  4. davej
    davej
    Jul 31, 2003
    85
    Sunderland
    I got the Philips VL1200 video sender. Ok, nowt special, very prone to interference.
    Note that this (and the OneForAll box above) connect with Scart cables rather than using the RF input/outputs if that's what you were alluding to, I'm not sure if there's any around that work with RF.
  5. noddingdino
    noddingdino
    make sure where-ever you buy it from allows you to take it back for a refund if it doesn't work...i tried to do the same thing without any joy...they seem to be a bit hit and miss!
    good luck!
