Wireless sender for Sky+, which one to get?
brumhee
I am trying to get Sky+ into the bedroom. I do not have an socket in the wall so have to go wireless (i dont want to tear the house apart).
I tried a 2.4ghz and there was too much interference I am now looking at a 5.8ghz but dont know which one to get. Not overly bothered about having all the features ust changing channel would be ok (and possibly playing an recorded show).
The ones I looked at at Maplin all say they cannot control Sky+. Is this just the record stuff and they can change channel or do they mean everything?
Anyones experiences with these or a recommendation would be appreciated.
brumhee
If you read the Q&As then you get this:
Q- If my Sky+ is downstairs, can I change channels with the Sky remote upstairs? thanks - paula
Answer- No sorry this product does not support that.
Q- Just wanted to let you know that I have one of these units and recently updated to a Sky+ box. The remote signals work fine (maybe I'm just lucky). - Mark Ravenscroft
Answer- Thank you for the feedback
Not as clear as the tone of your previous post made out. Hence the reason I am asking.
Stevenage Neil
I
A purely technical answer - A standard Sky remote will not operate a Sky+ box.
StevieBuck
We have Sky piped around the house over the RF2 output and use one of these to control the box from another room:
Marmitek PowerMid XL infrared extender set: Amazon.co.uk: Electronics & Photo
I can change channels on the Sky+HD box with the old (standard) Sky remote albeit without the Sky+ functions such as pause, rewind etc.
Are you saying standard Sky+ remotes don't do this, even though a Sky+HD remote will?
Stevenage Neil
Getting back to the original post, what I was saying is that the Maplin video sender quoted will transmit the Sky remote signals.
Stevenage Neil
Where have you set up the IR transmitter? It has to have a clear line of sight to the Sky box IR receiver.
brumhee
I had the extender that they included right in front of the box.
Stevenage Neil
Normally, the Video receiver units have a LED that flashes when the remote is used - does this happen?
stepea
Found this on the web
To reprogram the sky remote to control the sky+ box.
The sequence is:
* TV
* Hold Blue+select until LED flash twice
* 2
* Select
* Sky
Now the sky remote up and down channel buttons change the channels on a sky+ box.
To revert back, enter this sequence again but press the zero button instead of "2".
It does work
brumhee
I can't tell, the one upstairs does but whilst upstairs I can't see what the one down is doing :mad:
Stevenage Neil
OK, that says the video receiver is receiving the remote commands.
How close is the IR transmitter to the Sky box?
