D
Deleted member 173019
HI Guys, not sure this is the right place or not as my question could be considered hardware/software or device specific. ANyway, here goes:
I am running a Samsung Galaxy Android on 3 and I would LOVE the ability to be able to click print and have the paper copies waiting for me at home when I arrive, this would be handy as I use my device for work as does my wife (same phone/network as me).
So I need to buy a printer that's suitable, any advice as I am not sure what to look for, would software make ANY printer work, do I need a wifi printer, or what?.
At home I have a DLink DNS-323 NAS which is always plugged in, it has a USB slot, but this is only for port forwarding to a pc (which won't be turned on), I have a Belkin Modem/wifi Router and I have a TPLink Network switch. I do have network points throughout the house (if needed), but guessing that wifi would be the way to go?. SO once the hardware is in place, what software would I use? to allow me to print from anywhere?.
I am only using this for text etc, so not after all singing/dancing laser printers if possible.
Well, that's the challenge, any advice/tips from anyone who's done anything similar?
Many thanks,
Rich
Many thanks,
Rich
