Wireless PC to TV connectivity?
Discussion in 'General TV Discussions Forum' started by vipergrm, Sep 18, 2005.
  1. vipergrm
    vipergrm
    Sep 6, 2005
    3,796
    Belfast
    +578
    I have just recently purchased a 32" LCD TV by Acer and I want to use it's HDTV capabilities. However, here in the UK there are currently no DTV providers that offer this content. It seems the only way to play HDTV content would be via PC to TV. The problem is that it is not very convenient for my PC to connect to the TV (they're on different floors!).
    Is there some kind of wirless device I can get to enable me to do this?
    Also, I have heard about this Buffalo Cinema device that has wireless connectivity etc and seems quite versatile but it seemed to have got very bad reviews so I'm not sure about that.
    I would appreciated any help you can provide.
    Thank You once again! :smashin:
  2. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    I've read a few things about sending high-def material wirelessly and it doesn't sound very promising as some of the higher bit-rate stuff won't stream smoothly, never tried it myself though.
  3. vipergrm
    vipergrm
    Sep 6, 2005
    3,796
    Belfast
    +578
    That was certainly something I was/am worried about :confused:
  4. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    The pinnacle ShowCentre 200 has good reviews and there is also the Snazio 1350 (my preference as it will upscale DVDs).
    There is a lot of the discussion regarding wifi speed (54G considered a minimum) and HD transfer rate (i think both deivces max out at ~15Mbps but some HD is ~20Mbps)
    Both have detailed threads on this forum.
  5. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    Seems a bit silly to write it all again,..... so check THIS out for some information/options. :D
  6. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
    Showcenter 200 thread is here - http://www.avforums.com/forums/showthread.php?t=227029
    Maximum bitrate for wireless media streaming is around 12Mbps for these media streamers, which is fine for all the WMV-HD and MPEG4 (XVID, DIVX) media available on the net. If you want to watch the "illegally downloaded" MPEG2 HiDef stuff from the US, then any wireless media streamer will probably struggle with the very high bitrates needed for MPEG2 HiDef media.
  7. carlwi
    carlwi
    I've got the Buffalo Link Theater connected to my Sammy HD panel and ended up using a wired connection to my PC. Only the lowest bit rate SD material would play over my wireless connection (Netgear 54G AP), and even then I would still get occasional stalls and all this with excellent wireless reception on the device.
    To be honest since i've had it wired to my PC, the thing is amazing but wireless was a real waste of time for me.
    C.
  8. vipergrm
    vipergrm
    Sep 6, 2005
    3,796
    Belfast
    +578
    Great advice guys. Wow Monty Burns, you really did go through a lot to get it working wirelessly! To be honest though, I think I'll give the Wireless a miss this time. i think I'll wait until the X-Box 360 comes out. Surely there will be mods for this so you can use it as a Media Centreand Hi Def??? I wonder is it just a standard hard drive or could you connect a USB Hard Drive to the X-Box 360? Just a couple of thoughts as Hi Def content seems to take up a HELL of a lot of space.
    Seems that wireless hasn't quite cracked it yet for Hi Def. Thank you to everyone out there who has contributed. You really have cleared up some stuff for me!
