Wireless no longer working after fresh install?
Sparky83
I have been having problems with my laptop for a little while now so decided to do a fresh install of windows and wipe everything else.
I have now done this and the laptop works much better than before, quicker etc. Anyway, when i tried to connect to the inter wirelessly it says it cant and i need to install the drivers for it.
I have looked on the internet for them and thought i had found them but i have done what it said do but it still dont work.
The laptop is a Fujitsu Siemens Amilo Li 1818.
If anyone can help that would be great,
Shawn
Sparky83
i looked on there website but couldnt really find what i was after. I thought at one point i'd found something and downloaded it but after extracting it didnt work.??
bombibom
Please mention your OS next time in order to get a solution.http://ts.fujitsu.com/support/downloads.html
There's automatic driver update.Or select win XP or VIsta and try to find the wireless adapter driver.
It's usually in zip format so U need to unpack first and then find the file that say's setup.exe and click on it.Installation should begin.You may need to restart your laptop after the installation is finished.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
