Wireless Networking & Mac Powerbooks
Discussion in 'Networking & NAS' started by PFM, Jun 30, 2005.
  1. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    I've done a few searches on this and as yet havent come up trumps with a solution.
    I have a wireless network at home and wish to add my wifes Applemac powerbook to the network.
    The powerbook is a 400mhz Powerpc G3, running Mac OS X ver 10.3.9
    I have a spare netgear PCMICIA 511GT card and wish to patch it in to work with the powerbook to route at ~108mps (or there abouts) via the netgear DG834GT router/modem
    Can anyone point me in the right direction for a patch? :cool:
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Sadly, I dont think that's going to work. No Netgear OSX drivers, and the Wallstreet (I'm assuming it's a Wallstreet since that's the only PBG3 that will run OSX as far as I know) only has a 16-bit PCMCIA channel, so it wont support anywhere near 108Mbps 'cos there's not enough bandwidth (~8Mbps is likely the best you'll manage).
    Some pointers here for getting WiFi on older PBs .... I reckon ebay is probably your best bet for an old Orinoco based card.
    Cheers, Carl.
  3. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Or is it a Lombard ? Anyway, lots of help over at MacInTouch for this kind of thing (painful site to use, but it contains a wealth of information - if it can be done, it'll be in the readers reports somewhere !
    Cheers, Carl.
  4. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Thanks cwik
    I'll checkout the sites :smashin:
    Heres hoping ;)
