Quantcast
wireless network on HCPC??
F
fat tom
Ok I'm due to move into my new house and as its a bit of a posh effort the missus says I can't go drilling holes in wall etc for the network so I was thinking about wireless....
the question is what issues will this create will I have any interferience on my screen etc - I currently use a standard 28inch crt but will be moving to 42" plasma shortly.. also does the 11mb bandwidth support playing DVDs from a media server in the server room... :) (new house has a server room, sorry I am sad..)
anybody got any pratical experience with such a setup??
thanks
- Fat Tom -
MAW
You should't get interference, they're all tested and passed for that, not like cellphones!!! You do ont have the bandwidth t network play a DVD, even the latest 22mbit is tight/impossible.
S
spamboy
I use wireless for my htpc, and see no interference even though the card is next to the tv.
JSW
I use wireless and hardwired
Laptop and HTPC are both wireless
3 pc's upstairs are hardwired through a cable router/switch
2 printers hardwired through intel printserver.
Wireless is no good for streaming DVD so will be hardwiring the HTPC.
D
Dodgey
I have a wireless lan and the only thing it interferes with is my wireless tv and remote sender system (it uses microwave for the picture and radio for the remote control). I switch the lan off when watching TV in the bath & bed.
Similar threads
