Wireless Mouse
Discussion in 'Computer Peripherals & Consumables' started by pcpaz, Dec 20, 2002.
  1. pcpaz
    pcpaz
    At present if have a RF ATi remote which I use to control my desktop when viewing it on my TV in the living room.
    However using the cursor pad on the remote that mimics mouse movement is a little time consuming so I was looking at a wireless mouse solution (RF not infrared)
    Does any one have experience using one of these especially from another room, as using it in my living room will be approx 5-6 metres from the PC that is located upstairs in my bedroom.
  2. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    hi
    I have two RF mice from Logitech both of them only have a range of about six foot.
  3. halephil
    halephil
    May 24, 2002
    61
    Hi, check out the Gyration products:
    Gyration Ultra
    The standard Ultra Suite is excellent and I'm getting >5m without problem. The only criticism I can make is the very bright and distracting green LED they've used on the receiver module!
    Cheers, Phil
  4. pcpaz
    pcpaz
    posted in error
  5. Galaxy
    Galaxy
    Feb 22, 2001
    556
    Essex.........UK
    +14
    I am using a Trust Ami mouse 300, which is wireless and works fine up to about 3-4 metres with fresh NmH installed.
    It may have greater range when used with Alkaline installed but as I never use them I cant test it, but with the extra voltage available from these it should be better.
  6. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,682
    Do a search - there has been a previous thread on the subject.
  7. Garrett
    Garrett
    Apr 21, 2001
    43,658
    2
    167
    The best thief you'll never see.
    +8,416
  8. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    I got my keyboard and mouse from maplins - 30 squid.
    RF and a good range too.
  9. Sarge
    Sarge
    May 30, 2002
    147
    +10
    logitech and microsoft both now do bluetooth/wireless mice that have an increased working distance
  10. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Yup the gyration stuff is excellent if you want a cordless mouse that doesn't need a surface to roll on - but I wouldn't buy a cordless for gaming - the dual optical logitech is by far the best I've used for gaming - knocks spots of the MS ones for smooth and glitch free operation
  11. Sarge
    Sarge
    May 30, 2002
    147
    +10
  12. Dave_E
    Dave_E
    Sep 18, 2002
    3
    Have been using the Microsoft Bluetooth mouse/keyboard for a week or so. The range is excellent - up to 25" doesn't seem to be a problem, though needed binoculars to see the screen!
    HOWEVER, so far I've had to reassociate the keyboard twice and the mouse three times, which meant plugging the old wired ones back in.
    Its promising, but not perfect!
  13. Taz
    Taz
    WOW! 25 inches thats cool! :p
    ;) :D
    Taz.:cool:
  14. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Not only 25 inches, but he needed binoculars - now that's really worrying
  15. Dave_E
    Dave_E
    Sep 18, 2002
    3
    Oops, :blush: that should have been 25', its been one of those days...
