Wireless mouse & Keyboard
Discussion in 'Computer Peripherals & Consumables' started by Jazz Monkey Jr, Jul 13, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,030
    2
    4
    137
    Garstang, Lancs
    +1,584
    I have my plasma in a different room than my PC, so I need a decent wireless mouse and keyboard.
    The PC is in the next room so only about 10 feet away.
    Any recommendations.
    Also is my spec OK for playing HD movies.
    Win XP pro
    Athlon 2800+
    1024 DDR 400mhz
    Geforce Ti4400 128MB
    2 x 250 SATA HDD
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Gyration mouse and keyboard, love mine. :)
    As for HD, my standard reply .. currently the only HD that exists are WMVs and for those M$ recommend at least a P4 3GHz so your system is on the borderline.
    Future requirements for HD-DVD / Bluray playback are still completely unknown.
  3. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    I have Belkin RF keyboard and mouse and ASDA are currently selling the set for £20!
    If you go to www.wmvhd.com and scroll to the bottom of the page it will analyse your PC to see if it will paly WMV HD.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,030
    2
    4
    137
    Garstang, Lancs
    +1,584
    How far does it go, how do you rate it?
  5. branny
    branny
    Feb 26, 2005
    3,540
    83
    Pie Land
    +202
    I have the BTC (with thumb pad built in) and this controls my PC on plassie from 3m away.
    Got it off ebay (buy it now) for £18.
    Branny
  6. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    I can use it from 12-15ft no problem. I have just tried it from the kitchen facing the boiler and it works no problems (using the windows key to activate the start menu and alt f4 to close IE windows).
    the keyboard has programmable keys including email,web and play. The angle is good for thewrist and the key are "cushioned" to the tocuh. The mouse is optical.
    This is the model;
    http://catalog.belkin.com/IWCatProd...on_Path=/Root/ComputerAccessories/Keyboards/#
  7. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    I have the gyration too....the mouse is brilliant but I had a dud keyboard initially (and so too did a lot of people having read up on the net)
    Quite like the fact that it is so compact...doesn't take up too much space in the lounge where I keep my htpc
  8. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    I recently recieved the Microsoft Desktop Elite for Bluetooth, fantastic range and evn has media controls on Kbrd, play Far Cry\Call of Duty from about 8 foot away in my 32" LCD, mouse has no problems, can thoroughly recommend, costs about £75 though!
  9. davebrear
    davebrear
    Jun 13, 2005
    93
    Barnsley
    +4
    You CAN get a wireless k/b and mouse for £20.00, but if money is not object I would recommend splashing out on the logitec MX3100 wireless set. I bought mine for exactly same reason as you (PC on other side of wall directly behind LCD TV, and i am really impressed. Through the wall works like a dream. I bought this to replace a logitec MX500 wired mouse - which was the best mouse i had ever used. The MX3100 set with its MX1000 laser mouse (yes laser not LED) puts the old one to shame. I have never been a big fan of wireless before but this has definately converted me! AT £65.00 it is a bit steeper than some, but i think well worth it!
    Link to where i bought it:http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=83455
    Link to review of MX3100 set: http://www.casemodgod.com/cmg/Reviews-story--56.html
  10. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
  11. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    I found the problem with RF mice is that the range depends on your PC. Overall the range on my Logitech trackball is far superior than the RF mice I have had. Your best option though would be to go Bluetooth although they are expensive!
  12. northernmunki
    northernmunki
  13. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Still big compared to a gyration keyboard :rolleyes:
  14. TheBigK
    TheBigK
  15. RockySpieler
    RockySpieler
    May 23, 2005
    1,659
    Snaking the Lineup
    +116
    I brought one of the btc 9019 off ebay, it is USB, there is a version for ps2, but needs batteries in receiver as well as keyboard.
    I think it is excellant. I am typing on it now. It is compact, no separate numeric pad, uses letter keys, via Numlock button. Plug and play, I have not loaded drivers yet, my existing kb and mouse still work in parrallel.
    The joystick mouse is easy to use, handles, and ergonumic knee grooves actually work.
    On my version, there is a slight asetic flaw on the edge of the clear plastic cover on the remote control buttons (web buttons, plus vol up/dn, mute, ffwd, rwd, play/pause, eject, sleep).
    Recommended, and very cheap (I paid £21.54 delivered off ebay).
    Why pay more? It is good enough for Elonex....
    http://www.avforums.com/forums/showthread.php?t=186698&highlight=btc
    For operation from a separate room, the RF does not go through walls, but is better than IR types, bluetooth might be best if you have the doors closed.
    Regarding wmvHD Playback, I also have a xp 2800 and 1gb. The 720p clips/dl's are fine, however 1080p clips can be jumpy if you have background tasks. They are ok on mine if I disconnect from net, and turn off anti-virus/malware/hacker software. I have tried both a 9800se AIW and a 9500pro both similar results (they are close on Tom's hardware tests too).
  16. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    I am looking at getting a wireless mouse and keyboard. I have a PC in a cupboard in the next room behind my plasma that I want to control. Distance is around 9' or so.
    I have been looking at the BTC 9019URF as a cheap option as all I want to do is use it to casually control the PC, it is not going to be in use very much.
    Does this not work through walls at any distance ?
    Any alternatives around the same price that will work through walls ?
