Wireless Monitor Connection
Discussion in 'Networking & NAS' started by Forestred, Feb 11, 2005.
  1. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Has anyone heard of one, I know that you can get RF connectors to allow your printer to be in a different room to the PC, what I'd like is the PC to be in a different room to the monitor, keyboard and mouse - does anyone know of anything that can sort this?
  2. mephistopheles
    mephistopheles
    Some kind of video sender for the monitor signal, probably would have audio, but I suspect they're normally for TV connections, so you'd need a transducer, too.. Try Keene's at http://www.keene.co.uk
    An RF K/B and mouse for remote PC control, eg Gyration Ultra Suite, or you could use an RF remote, eg X10 mouse remote.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,096
    Manchester
    +711
    What you want is a wireless KVM switch. I know a bit about KVM systems but have never seen a wireless one. These days most use UTP network type cable as the transimssion medium..
    Companies like Avocent have thsi as their main business -
    www.avocent.com
    These are mainly professional suystems used in dealing room, call centres etc. so I would expect the cost to be prohibitive.
    You may want to iuse Google with KVM and wireless as search terms.
    Chris Muriel, Manchester.
  4. mephistopheles
    mephistopheles
    The snag with that is a KVM switch is likely to degrade the video signal to an unacceptable degree. I have a Belkin x8 port KVM, which works very nicely, but it does affect the picture quality a fair bit. It's not a problem for w/s and server use, because it's hardly noticeable in general use, but I wouldn't want to use it for HCPC.
    Conceivably the more up market equipment might maintain signal integrity better than my Belkin but, as you say, it's likely to be expensive.
