Wireless Media Player with HDMI
Discussion in 'General TV Discussions Forum' started by ColdKilla, Jul 31, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Does such a thing exist? I was tempted by the pinnacle system until i discovered it doesnt have DVI or HDMI connections on it!
    CK
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,478
    Windsor
    +1,046
    not yet. They need to sort out a wireless/home network standard that is secure enough.
    Problem is that HDCP is tightly protected, stopping you from simply recording the bitstream coming out. All links in the chain are tightly controlled.
    with a wireless device, thats much less controllable, as by definition the bitstream needs to be broadcast over the air. Even wired network woudl be an issue.
  3. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
    You could get an imported LinkPlayer 2 from Japan - http://www.virginpulse.co.uk/catalo...id/34?osCsid=28f79724b72ce03404251d3a771df062
    But suggest you research the firmware situation carefully.
    I'd also question how useful DVI or HDMI really is, rather than using component. Ater all, there's no HDCP to worry about.
  4. ErikX
    ErikX
    Sep 14, 2004
    84
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    DVI is far better quality then component
