alanfleming
I am having a problem with the wireless connection from my PC to Modem Router.
Modem router is a Siemens Gigaset SE587. PC is fitted with a Realtek USB Wireless 802.11g dongle.
All had worked fine for months until recently when the PC's Internet Connection (via the wireless network) has started dropping out for no obvious reason.
I have noticed using the "Realtek USB Wireless LAN Utility" that the display of Wireless Signal Strength is fairly constant at around 90/92%, but the Link Quality display fluctuates around 90% and occasionally drops much lower.
Occasionally Link Quality drops to around 50% or lower and the PC's wireless connection to the Internet is then lost.
I can sometimes work OK for many hours without a disconnect. At other times it is dropping off every 5 to 10 minutes. Wireless router and Internet work fine to Laptop, etc..
I don't think I have changed any settings since the system worked more reliably. I am wondering if another wireless network within range could be interfering with mine. How can I check for this ? Any other comments / suggestions welcome.
Alan.
Alan.
