Wireless keyboard/mouse recommendation for Mac Mini
Discussion in 'Computer Peripherals & Consumables' started by mcburnie, Apr 23, 2007.
  1. mcburnie
    mcburnie
    Sep 20, 2005
    3
    I get my new Mac Mini soon - went for the 1.83Ghz with 1gig RAM. It'll be my first Mac!
    I intend to use it as a HTPC solution - thanks for all the advice here in this forum which will come in handy I'm sure.
    Can anyone recommend a combined keyboard/mouse solution that looks good and will work well in a "living room" environment? By this I mean having a reasonable range and being useable without a desk surface for basic navigation, surfing, email etc. I expect I'll use the Apple remote for general viewing.
    Will cheapish PC USB wireless keyboards work OK on Apple? I note that many of them don't seem to quote Apple compatability.
    I like the look of the Logitech Dinovo Edge which is expensive but looks great.
    http://www.ebuyer.com/UK/product/119977
    Is there anything else I should consider?
    Thanks in advance!:thumbsup:
  2. stuart07970
    stuart07970
    Sep 28, 2004
    2,624
    Slough
    +359
    Congratulations on your new machine!
    The mac can handle any cheapie keyboard, as long as its USB
    Logitech do a very nice white set, as long as you're right handed.
    But for me its the apple wireless keyboard and mighty mouse.
    (The mouse takes a bit of getting used to, and you do need to keep your hands clean, but IMHO its the best!)
    cheers
    stuart:smashin:
  3. medicalgiant
    medicalgiant
    Mar 1, 2005
    264
    +24
  4. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    I use this and would recommend it :)
  5. mcburnie
    mcburnie
    Sep 20, 2005
    3
    Thanks for the replies - I've went for the DiNovo!
    Looks good, and has an integrated mouse pad.
    It arrives later this week :thumbsup:
