Wireless /IR/ Bluetooth Speakers
Discussion in 'Home Cinema Speakers' started by wintermute, Jul 15, 2005.
  1. wintermute
    wintermute
    Hello All
    First post for me so be gentle. Does anyone know of any useable wireless options for surround. I had it explained to me at great length last night why cables in the new living room are wrong. I am therefore in search of a wireless solution. I see from a googleise that there are a few options but how do they sound?
  2. blasthand
    blasthand
    May 29, 2004
    242
    Yateley, Hampshire
    +11
    Wintermute,
    Sounds like you should take a look at the Yamaha YSP-1 all-in-one. It doesn't do the full job of a separate surround system from what I've read...although there is some pretty-good feedback for it. Just search the forums for YSP and you should find plenty.
    http://www.yamaha-uk.com/sound_projectors/?product_id=15
    Cheers,
    Mark.
