Question Wireless interference issue
Discussion in 'Subwoofers' started by phils_wicked, Aug 15, 2018.
  1. phils_wicked
    phils_wicked
    Mar 11, 2003
    563
    Luton (UK)
    +16
    Hi all. I have recently purchased a Monitor Audio wireless kit in order to run my Xls200.
    It's the WT1/WR1 as seen here...
    Monitor Audio WT-1 / WR-1 Wireless Audio Transmitter & Receiver Kit - Wireless Accessories - AudioVisual Online - UK Home Cinema and Hifi Specialists
    It's all hooked up just fine and works. However I seem to be getting some random interference in the form of pops and crackles. The blue connection light flashes and occasionally drops out too.
    The wiress reciever is on one side of a door frame and the transmitter is of the other (both in the same room, just either side of the doorframe). I'm wondering if the interference is coming from the BT homehub or mains...
    Has anyone used one of these kits or similar? I'm looking for some tips really.
  2. BigAl217
    BigAl217
    Apr 4, 2004
    256
    +23
    I recently got one of these also and with my amp off I was getting some sort of pick up on the receiver that caused the sub to output a little noise. Not loud but audiable in a quiet room. I also had the flashing blue light on the receiver. I even noticed it first thing in the morning when in theory everything shpuld have been asleep as nothing had been on. I assumed it was picking up wireless interference although it is a long way from my router. My sub has a crossover control on it that was up at 150hz but as my AVR crosss over lower I turned this down to 90hz and this has sorted the issue. I still occasionally notice the blue light on the receiver flashing when it should be asleep (red) but I’m no longer getting output from the woofer so guess the sub dsp is rejecting the signal due to the lower crossover setting. Don’t know if your sub has a crossover control but worth trying if it does.
    My transmitter and receiver are about 5 meters apart in the same room.
  3. larkone
    larkone
    Apr 21, 2006
    4,389
    134
    North Essex
    +1,260
    It works in the 2.4Ghz band so DECT phones/microwaves/wireless can all interfere with the signal.
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,178
    Poole
    +11,815
    @larkone - they oprate in different parts of the 2.4GHz band.
    I had a customer who had connection problems when router and device were very close.
  5. phils_wicked
    phils_wicked
    Mar 11, 2003
    563
    Luton (UK)
    +16
    Thanks all. I've not had the time to problem solve the issue as yet but will probably spend some time this weekend.
    I'm guessing it's going to be the homehub personally.
  6. phils_wicked
    phils_wicked
    Mar 11, 2003
    563
    Luton (UK)
    +16
    Wish I could report about how I solved this issue however..... It's gone. For whatever reason the interference has not been a problem since the first time I hooked it up. The only change being that I had moved the wireless receiver slightly further away from the subs amplifier plate and used a couple of better cables to connect it all up.
    I'm currently loving wireless subs lol
