Wireless help system link
Discussion in 'Xbox Forums' started by ste0633, Mar 16, 2006.
  1. ste0633
    ste0633
    Oct 4, 2005
    57
    I've just bought 2 netgear wge111 wireless adaptors. The plan is to set up an xbox 360 and xbox for system link play on Halo. All works ok but after a period of gaming the connection is dropped. I've changed the ip address on one of the wge111 but still no sucess. The distance between the 2 is about 10 feet through a thin partition wall, both are on highish shelves
    Is it possible to link a 360 and an old xbox without problems?
    Any pointers would be appreciated!
  2. cwilso
    cwilso
    Mar 24, 2006
    108
    Scunthorpe
    +7
    you running an ad-hoc network?? suposidly when sbox360 is running an xbox game it reverts to that state ie has no control of xbox live in the guide button so theoretically yes. Ip conflict shouldn't be a worry on ad-hoc if the SSID is different to any existing networks. you tried with a cable to check both boxes are working??
