wireless Equip & Xbox live
Discussion in 'Xbox Forums' started by UncagedTyphoon, Aug 9, 2004.
  1. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    I know this has been covered many time but I have found a wireless router
    which Im thinking of buying but I cant seem to find the other bit (bridge)that would work well with this router and me Xbox.But im also not suck on this option if any one knows a better set up feel free to put forwards your opinon the link below is for the wireless router im thinking on at mo :confused:
    http://www.amazon.co.uk/exec/obidos/ASIN/B00005ARK3/pd_ka_0/026-1581930-0849220
    :lease:
  2. Squiffy
    Squiffy
    May 23, 2002
    9,632
    Ashford, Kent
    +2,794
  3. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Yo Yo Typhoon (or is that Buffoon) :D I have the very same Wireless router and I use the WET11 with no probs.
    Matt
  4. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    the amount of time you are on live I would have thought you have problems with this set up :D
    must be another reason then :thumbsup:
    :rotfl:
  5. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Well get your fat ass on RS3 then tonight :laugh: then maybe we can bitchslap some mother*******. :devil:
    Matt
  6. Bonesy
    Bonesy
    Feb 22, 2002
    1,143
    Wiltshire
    +27
    wow, the bridge thingy is very expensive for what it is...
    followed your lead, just ordered the cheap linksys for replace my blown one.
    why do people buy a 54M G system... what are they connecting to?
  7. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Whats a 54M G System :laugh:
    Matt
  8. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Well you buy a 54g system if you want to move files around the network at a decent speed and if you use xbox media player to stream video, mp3 etc wireless.
    Try that with WET11. Not Only this but connecting an xbox up to the net for live is the smallest part of my wireless network. I also have a laptop and another PC hooked up using wireless. TO get the lot connected cost around £150, not bad considering its decent linksys kit.
    Incidentally going Wet 11 using the Linksys kit would have saved my around £40 - £50 :rolleyes:
  9. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Harris all i Want this for is Xbox live use maybe a lap top now and then
    but the sole point is to stop a 30ft cat cable being streached across from comp room to bedroom for xbl so from your note the wet 11 and router suggested in perv note will cope
  10. Bonesy
    Bonesy
    Feb 22, 2002
    1,143
    Wiltshire
    +27
    industry speak
    ;) 54meg 802.11 G spec.
    (did I get away with that?)
    agree with you Harris, if you're creating a network, over small distances, 54M makes sense.
    but if you're primarily getting files, links, etc from a 1/2 meg adsl link, the wlan bit isn't really the bottleneck, is it.
    anyway, after all that, I bought a 54M linksys box!
    only cos after 2 hours surfing for a deal, and 30 mins in PCworld, I realised that you spend £70 on a standard adsl modem, or £75 on a 11m and modem, or an extra £15 gets you 54M.... ie it's really no saving to go for the old 11M kit.
  11. Bonesy
    Bonesy
    Feb 22, 2002
    1,143
    Wiltshire
    +27
    yep, lowercase g is proper nomenclature
  12. Bonesy
    Bonesy
    Feb 22, 2002
    1,143
    Wiltshire
    +27
  13. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Well that was my point. My saving would have been £40 on the whole wireless network. Not much of a decision really is it.
    Incidentally I went down the WET11 route on a budget once before. I couldnt get it to work right. At the end of the day we are talking about pennies in the scheme of things a couple of games at best. Might as well get the right kit.
